Strange Noise
Old 07-24-2011, 07:59 AM
mastery's Avatar
mastery
mastery is offline
Mine makes all kinds of sounds. It's a Harley. Take a day in the garage and check everything out, using your service manual to guide you. Seriously, it may be a lot of different things...I'd check for a cupped tire first.
Old 07-24-2011, 08:18 AM
dansflhti's Avatar
dansflhti
dansflhti is offline
For many years I've been wearing a 3/4 helmet.Last week I bought a new HD Hybrid 1/2 helmet.Now I have an unbelievable amount of new noises,woo woos and clicks and clunks,but the radio sounds much better.
Old 07-24-2011, 09:20 AM
hfdarson1's Avatar
hfdarson1
hfdarson1 is offline
Default BoB n Ohio
I had the same thing on my 2008 Pacific Blue Ultra. It was the rubbers mounts on the mufflers.
Jerry
Old 07-27-2011, 12:01 PM
hfdarson1's Avatar
hfdarson1
Default Some what resolved
Dealer gets with Harley Tech Support. Tech support states that the teeth on the belt are too thick. Tech support states this is a know situation. If you change belt you'll have same problem. Solution:
1. Use a file and file down belt teeth.
2. Leave it alone and the teeth will wear down and noise should stop.
Mean while spray silicon on belt every once and a while to reduce noise.
I told dealer to leave mine alone. Dealer stated the problem is stored in the computer for future problem if it arrives. Hopefully belt manufacturer is or has redesigned belt for new bikes.
Jerry
dynarider1821
2014-2023 Touring Models
11
01-18-2018 04:35 PM
Iarecobra
07-27-2015 02:46 PM
Riven02
09-10-2013 10:31 AM
PDDGM
08-23-2013 04:51 AM
Big Pa
05-25-2009 03:49 PM
Quick Reply: Strange Noise
