Dissconnect Battery before PCV?
While disconnecting the battery or removing the main fuse is not a bad idea when servicing any electrical component you do not need to unhook the battery cable when installing the PC-V
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
An integrated Circuit (computer chip) can short out with as little as 25 volts, that is far less than the static electricity shock you get from touching a door handle which is usually around 2000 volts (talking volts, not amps). To paraphrase, the more brain power the device has the more you need to protect it by pulling the power. As Jamie just said, you do not need to pull the power for a PCV.
