Leaking Primary
Leaking Primary
Gotta a small but steady leak from the bottom of the outer primary cover...doesn't appear to be running down from anywhere , but right by the drain plug (not on the drain plug) on the outer cover . I bought a new outer primary gasket, but thought I would get any info I could from you guys. And is there anything special I need to know in regards to replacing that gasket. TIA
Oh and it's an 07 Road King...
WTF, another inner primary seal leak...add it to the list
https://www.hdforums.com/forum/touri...t-repairs.html
