Rubbing Alcohol. The bike detailer at my local dealer recomended it and it worked. It did take off the wax requiring that I wax the area again but unlike Naptha, WD-40 and other hydrocarbon products it won't get into the clear coat.
Naptha won't hurt clear. Correctly cured and dried clear will withstand more than that. Wax yes, clear, no. Avoid getting something that you are going to need to scrub with. Hydrocarbon or not your going to have to have a buffer to get the swirls out.
.....BABY OIL....good old fashion johnson and johnson....rub it on with a rag...leave the rag on the spot ..wait a 1/2 hour or so and wipe it off....other stuff will work...I do not recommend PB BLASTER as it is a solvent and solvents can damage paint/rubber/ vinyl etc....wd-40 works too but it has carriers in it that I am not too sure are completely safe for all paints..
Charcoal lighter fluid works great on tree sap but try on a small or out of direct sight area to see reaction cause different paints react differently to some chemicals.
