Help,Check Eng Light
I have a 01 RD-King,And I put the screamin`Eagle Ignition and coil on.The bike seam to run ok,but the check engine light comes on after starting the bike,By the way the bike is carb. The codes are 42,56,42 is camshaft position sensor and 56 is camshaft position sensor and crankshaft pos, sensor timing or signal error.so with that I took the new SE Ign. out and put the stock one back in and the error codes are gone,so the question here is I guess is.How do I clear the the error codes or reset the computer with the SE Ign.
Thanks,Jeff
Thanks,Jeff
RE: Help,Check Eng Light
Jeff
Take a look here https://www.hdforums.com/m_64805/tm.htm
Don't know if it is possible to run that coil without setting a code with the ion sensing in that bike.
