Dry Erase Markers???
...... TOC ?
..... TOC ?
..... totally open cockpit ?
........ terribly oversized component ?
..... the orgy complex ?
... true organic compost ?
....... Thadeus Oglevy Christianson ?
.... to overpay consistently ?
......... tough opinionated competitor ?
..... traffic override compensator ?
..... TOC ?
...... TOC ?
..... TOC ?
..... TOC ?
...... TOC ?
..... TOC ?
..... TOC ?
Tactical Operations Center...its a military thing...lol
I find I have a very good memory but it just does not last that long, I was thinking on trips about writing key directions on the inside of my wind deflector. Has anyone tried any products that come off easily?????? The dry erase marker directions say for any non-porous surface, but being plastic it is kind of porous????
This thread took a twist.... I'm a Battalion S3..... I LIVE in the TOC. It seems a bit odd to see "TOC" on HDforums.
You could go with a "knee board" concept and laminate a piece of card stock or an index card with a lamination that you can write on with pencil and erase - use over and over. I did this for my PPC (yet another military acronym) Performance Planning Card for fuel burn calculations, hover power, max torque available, jettisonable load, VNE, VSSE, etc etc. Make it what ever size suits you and tape it in place on your tank dash, back side of wind shield, where ever you want it/can read it. Office Max or Office Depot should be able to hook you up.
Pencil won't run in the rain.
T
T
You could use an 'Auto Writer' It is a wet erase marker. They are used in the bodyshop industry to make notation's on car surfaces glass or painted. It will not come off in the rain. Just wash with soap and water or use windex to get it off. Check with any autoparts store they will have them.
