Tourpack bulb replacement
Found this on another site, posted by a "cleonard" (credit where credit is due):
The 198 bulb is the "heavy duty" version of the 1157. The 198 is a little dimmer, but more robust (vibration resistant). If you can't find a 198, the 1157 will work fine. Some auto parts store sell a 1157LL. The LL is for long life. It's nothing more than a relabeled 198.
More robust/a little dimmer suggests a heavier filament, Nice to know though. 1157 is certainly much more readily available.
That's good info Krow, because both Walmart and Autozone here have the 1157LL for about $3 bucks for two. No telling what the dealership charges.
The brake light filament on the 198 is brighter then the 1157. 29 Watts versus 27 Watts.
See the below link for all the specs. I also use the 1157LL since they seem to be more widely available. Even Walmart carries them.
http://www.gelighting.com/na/busines...ll_catalog.pdf
On my 2011 UC, one of the front running/turn signal bulbs went out...that is, the running light part of it...turn signal still worked. I pulled the bulb and discovered it was a 198. I had some 1157's handy so I used one. As far as the running light portion is concerned, I can't tell any difference looking at them side-by-side.
The spec mentioned earlier had to do with the brake (turn signal) part of the bulb. By turning on the 4-way flashers on the bike, it looks like that both are the same brightness. So, I think the 1157 is a good replacement for the 198. The 1157LL might be even better, as far as, vibration resistance.
Well, I did a test to see if there was a difference in brightness with the brake engaged. I have the 198 on the left, and the regular 1157 on the right in tourpack. I tied a long string to the front brake where I was well behind the back of my motorcycle and engaged the brake, and as far as I can tell, there's no difference in brightness with either the tail light, nor the brake light.
