Shifting Issues
Shifting Issues
I've searched the site and haven't found a thread specific to my issue. Friday night I noticed it was hard to shift my bike occasionally, 3-4 four times when I was downshifting coming to a stop. Once or twice when upshifting into third it seemed like I had to stomp it pretty good. I looked it over and nothing on the shifter or linkage seemed to be grabbing. Sunday morning I went on about a 100 mile ride and didn't seem to have any issues. Sunday night it was acting really bad and I noticed at stop lights the bike was trying to pull me forward like the clutch wasn't fully engaged. All the fluids are good. My buddy and I tried to adjust the clutch based on the instructions in a service manual and it's still doing the same thing. Now, neither of us are professional mechanics, so I don't want to rule out the possibility that we didn't get it adjusted properly, but I would love some advice on what the problem could be.
Right after I got my '08 SG I started having shifting issues. Turns out it was the shifter. If you look, it runs inside a sleeve on it's way to the transmission. When I took mine apart it was covered in thick, hard grease causing the shifther to bind on up shifts and down shifts. I cleaned it, re-greased it and then drilled the sleeve and put a grease fitting on it. Has worked perfectly ever since. Take a look at yours and see if it's binding.
3/4 turn is fine but 1 won't hurt if you like the clutch release closer to the grip. Make sure you have loosened the cable fully before adjusting the clutch. Then be sure the set screw doesn't turn when you tighten the nut.
Thanks for all the good advice. Played with it some more last night, went a 1/2 turn on the set screw and it seems to help. Another friend came over and looked it over. He suggested I start using a different oil than the Harley, other posts on here have helped. I'm gonna check out the sleeve issue listed above.
