My Suspension Upgrade Report - Ohlins and Monotubes
#41
Im leaning towards the 3's now... If i had a Ultra or Tourpak - id maybe put the 6's so external resovoir is easier accessed and i agree looks cool..but since the Street Glide is lower and closer to the pavement maybe the 6's will prevent the bottoming out vs the 3's ! AHHHHHHH !!!!!... i keep bouncing back and forth..
#42
Neither do mine, even when loaded up with the kitchen sink! First shocks in almost 40 years of Harley ownership that don't bottom out at some time.
#43
#44
Ditto for my $400 HD Premium Ride shocks and the hand adjuster makes the preload a cinch to adjust.
Yup. I ride aggressively with my sport-touring buddies in the mountains and always run out of cornering clearance long before the shocks are pushed anywhere near their limit.
#45
How do you like the HD Premium Shocks? Can you compare them to any others? These are one of the sets I am considering when I upgrade.
#46
#47
BTW - i tried the HD P-shocks... better than stock and similiar to progressive shocks.. but i still think not good enough for the stock height of a FLHX which i lower than a Ultra series.....wouldnt be surprised they make them for HD.... to what i understand, your comparing Apples to Prunes when talking about Ohlins and HD shocks...
#48
tj tells you in his post! Like you he has an SG and has replaced his stock 12" shocks. Howard can supply his shocks in different lengths, so give him a call and discuss your requirements, so he can recommend a suitable length.
#49
Stock on Street Glides and Road Glide Customs is 12" , the #3-#1 are 12" , I went with the #3-#3 , the lowest you can adjust these is 12 3/4" , stock on other bikes is 13" , so I'm 3/4" taller for my bike 1/4" lower than other bikes , I wanted the longer stroke of the #3-#3 over the #3-#1
#50
