Just getting used to the new trike, the problem I am having is the Harmon Kardon radio works fine sitting still and riding close to 40mph. Then everything turns to static. The rider to pillion communication is ok at all speeds, the radio drops out when talking as it should, I have a gps installed in the AUX port, it works fine at all speeds, when the gps is on everything else is off. so I run with the maps on the screen only. Anyone having the same problem with the Radio turning to static after about 38 mph? Also it seems to go to nothing but static when other vehicles are going by.
Any chance you have the CB turned on? Even if you don't use it if CB is on in the display anyone talking or any type of signal that breaks the squelch will cause it to drop out. Also check that the weather band is not on alert.
