Install wheel bearings letter side out??
Old 07-25-2011, 03:11 PM
Feeeeg's Avatar
Feeeeg
Feeeeg is offline
Let me Preface this by saying I manage a car parts store and have come across this on cages.
Not sure it relates to HD or not, but since HD is sort of in bed with Ford, my guess is it has to do with ABS.
The newer focus's use a bearing in some way shape or form that has the tone ring inside it. If you install a bearing on a focus with the wrong side out, the abs light will trip..
Like I said not sure if this is the reason or not, only my guess..
Old 07-25-2020, 06:26 PM
F150HD's Avatar
F150HD
F150HD is offline
Received 1,292 Likes on 850 Posts
Originally Posted by dawg
There are not numbers on letters/numbers on both sides. The black seal of the bearing has numbers on both sides, but the internal race of the bearing has letters/numbers on one side only. That is the side that faces out. In the attached pic, the red arrow points to where you will see the numbers.
I realize this thread is old so things may have changed, but the All Ball-s bearings I just received are absolutely identical on each side. Theres numbers/letters on the seal and nothing on the inner race.
So which side goes inward in that regard? 2012 Ultra (no ABS)
Old 07-25-2020, 06:40 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,314 Likes on 1,861 Posts
Your 25mm bearings have No orientation other than to NOT put them sideways ... just stick them in (of course putting the LF & RR bearing in first)
F150HD (07-25-2020)
Old 07-25-2020, 06:52 PM
F150HD's Avatar
F150HD
F150HD is offline
Was reading some bearing threads before doing an install (plus its super hot and tropical here today and rain so not working on the bike, All Ball-s or Sweaty *****, one in the same). Anyway, your posts on the Jims tool.....useful. The Pit Posse tool has the same flaw, so plan is to install but flip the one piece around before driving the bearing home. Huge thanks for the insight.
I do find myself wondering how some folks have these catastrophic bearing failures so quickly and frequently. One guy quoted it happened three times under 10k.
Old 07-25-2020, 07:16 PM
multihdrdr's Avatar
multihdrdr
Flip both sides ... the "Flat" disc will always be reversed (no reason not too), but on the "piloted" installer side, start with the pilot and then flip when the large diameter just starts to enter the bore, but the bearing hasn't reached the center sleeve yet. Then Flip and finsh off at any torque up to the axle nut torque spec.
I would suggest trying to keep wheel horizontal to keep the sleeve vertical while installing the second bearing. I use a 5 gallon bucket with a big hole cut in the side for access.
Also insert the axle once for sleeve alignment just before that final bearing "seating"
Then insert it again after the bearings are seated. If you feel the sleeve had moved slightly during installation because it had to move again into alignment, then us the Tool again
PC12Driver
Shovelhead
07-13-2018 06:39 PM
Dynaglide92
09-05-2017 09:09 PM
oldschoolhd
05-23-2012 10:51 PM
mrreb57
Shovelhead
05-30-2010 10:56 PM
rodney123456
04-05-2010 03:57 AM
Quick Reply: Install wheel bearings letter side out??
