"Torque Cones"...not for me.
Old 07-07-2011, 03:13 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
Originally Posted by NoCoLoco
Torque cones/power cones are a band-aid for a shity exhaust system, besides, the restriction needs to be at the other end.
Not necessarily true, hence stepped head pipes. Scavenging, back pressure equal length head pipes etc all play a huge part in a pipes performance. Take for example the stock head pipe with a cat on the newer 96 inchers. You pull off the stock pipe and replace it with a non cat version, even though it is baffled, and you will feel a distinct seat of the pants difference in the torque curve otherwise described here as the perkiness in certain RPM ranges. Many either add cams to the stage one to compensate, or live with it for the better overall diveability and a cooler running motor.
Old 06-29-2022, 03:37 PM
armydad11b30's Avatar
armydad11b30
armydad11b30 is offline
Stage I
Default I just came across your post, I had problems with my 14 flhxs 2 into 1 with103 with big bore kit overheating kicking check engine light on during initial 500 mile break in done all at once it never had a problem got home put cones in and it runs hot
Originally Posted by Vivid Glide 103
It is some sales pitch, huh? Not trying to sale, just posting my experience with them. I have no problem tossing them out.
As far as the QQ baffles, too spendy for me. I will just suck it up until I do stage one and get it back from the front end.
There is nothing wrong with the head pipes, there is just a little less than there was. They still seat properly, seal perfectly and everything. I do want to get V&H Power Duals eventually.
Old 06-29-2022, 04:17 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,599 Likes on 2,722 Posts
Welcome to HDForums! His last activity on this site was 9 years ago, so I hope he's still alive to see it.
Charles:
09-15-2019 05:22 PM
Whtwolf14
03-10-2016 08:52 AM
8ntsane
07-10-2015 10:33 AM
blarg
03-11-2015 02:08 PM
jm04
06-10-2010 12:26 PM
Quick Reply: "Torque Cones"...not for me.
