Road Zeppelin : Two 13 hour days in the saddle
I have logged some miles on the RZ since I bought it, but the true test was my 4th of July weekend trip. I have to say this seat is amazing! absolutely no backside discomfort.
I only had 1 problem with the seat. on the way, one of the wires pulled from the harness, and the compressor stopped working. It was a simple fix, I just had to push it back down. Now that I'm back, I will check out my options to make sure it doesn't pull out again.
The best thing about the RZ, is that you can adjust the bladders while riding, reducing/changing the pressure points. It was just too big of a seat for me.
I almost got one. The RZ is a good seat, no doubt. However, I found that it sits you at least 1" higher than any other seat I tried. I'm 6'2", so height wasn't an issue, but I just didn't like sitting that much higher.
You are correct, It is a GIANT Seat, and does take away from the aesthetics of the bike, and it does raises you up a bit. with no air, it is about the same height of the stocker, but once you air it up, it does move you up a bit.
It is awesome to be able to change the seat (air pressure) on the fly.
Cycle Pedic Touring Seats offers riders and passengers the ultimate in comfort by taking pressure off the prostate and tailbone area. Using multiple levels of comfort including: memory foam, mold injected polyurethane foam, shock absorbing gel polymer, and a channel for the prostate/tailbone, Rush guarantees Cycle Pedic Seats will displace more weight than any other seat making this the most comfortable seat in the industry.
http://www.rushracingproducts.com/Cy...esentation.pdf Click the link for more information.
Ride on Us! --- If you are not happy with the product within 10 days, return the seat for a full refund!
Three styles available with retail price range of $399.95 - $599.95
When we installed our RZ back in '06, the wireharness plug under the seat was tied to the frame tight in front of the battery, making it very hard to install the seat. I clipped the plastic ties back several inches, and found a lot of slack in the harness, then retied the harness, giving me plenty to easily plug in the seat.
heavymetalthunder
05-28-2018 07:12 PM
benningtonr
2014-2023 Touring Models
20
03-24-2018 08:38 AM
