Is it OK to charge Cell Phone with cigarette lighter plug in?
#31
Check out the specs on the 2012 Harleys. Their web site now brags about all the power accessories you can plug in ! The paragraph below is from the Ultra specs, and it shows a picture of the cigarette lighter plug. A similar spec on the Limited page shows the plug in the tour pak, stating it's backed up with a 15 amp fuse.
Harley-Davidson® touring means maximum comfort in all conditions and the capacity to add whatever enhances and personalizes your ride. The high output charging system provides an electrical capacity robust enough for your add-ons: heated vests, heated seats, heated handgrips, lights to showcase the engine, you name it. So if you're hell-bent on two-wheeling it, we make sure you've got the juice to do it your way.
#32
#34
I saw some pics recently from another post that explains part of the lighter socket problem - - the positive center of the socket (assuming it's wired correctly) has a really wide contact, and if your plug is mostly metal or has long side contacts it's possible to contact both + and - at the same time and short out the plug. I make sure the side contacts on my cell charger doesn't hit the center extension and it works just fine.
#35
#37
#38
