Removing Pro Pipe Baffle?
Old 07-01-2011 | 09:08 AM
Rickr01's Avatar
Rickr01
Default Removing Pro Pipe Baffle?
Can someone please fill me in on how to remove the baffel and I'm assuming the end cap will have to removed as well, on a Vance and Hines Pro Pipe? I want to spray paint the baffel with a high temp flat black to hide the rust that has formed on the baffel. Thanks
Old 07-01-2011 | 10:24 AM
Mr. Wannabe's Avatar
Mr. Wannabe
There's an allen headed bolt that holds the baffle in toward the end of the pipe. Pull the bolt out then grab the end cap and yank it out. May take some wigglin'.
Old 07-01-2011 | 10:32 AM
ULTRA Gramps's Avatar
ULTRA Gramps
Mine has two cap headed allens. Looking from the back 3+6 oclock on the side of baffle
Old 07-01-2011 | 10:33 AM
ULTRA Gramps
Sorry 6+9oclock
Old 07-01-2011 | 10:40 AM
Mr. Wannabe
Yeah, think two bolts is right.
Old 07-01-2011 | 11:01 AM
stro1965's Avatar
stro1965
Not knowing which version of the ProPipe you have...I THINK the baffle on the ProPipe BP doesn't come out. Well, maybe with a blowtorch.
Old 07-01-2011 | 11:11 AM
Rickr01's Avatar
Rickr01
Thanks alot guys. I don't have the BP, I have the standard chrome. Thanks again
Old 07-05-2011 | 09:06 AM
Rickr01's Avatar
Rickr01
Well Folks I'm pretty determined but in the case of this baffle, I've given up! That damn baffle and end cap isn't coming out of there without mucking it up good. I ended up taking the high temp spray paint I purchased, and sprayed it in a cup and brush applied it in light coats. Looks just fine..It's only inside the end of the muffler after all.
Old 07-05-2011 | 09:47 AM
joflewbyu2's Avatar
joflewbyu2
After removing the 2 bolts mine came right out. I removed the packing to see what would happen. A lot louder but no reduction in low end pull. I purchase some more 1/4" packing and did both chambers with it 4 rolls around. Now it quieter than stock baffle. Originally came with packing further up in pipe in the 2nd chamber and loose steel wool around the tip baffle in 1st chamber.
Old 07-05-2011 | 10:55 AM
Rickr01's Avatar
Rickr01
Man, I used penetrating oil and everything I could think of. Wouldn't budge. I decided it wasn't worth damaging the end cap or pipe.
webermetal
Exhaust System Topics
06-05-2018 08:04 PM
Campy Roadie
13
04-07-2018 04:25 PM
SiggerTX
01-24-2016 06:39 PM
HOTROD1300
04-04-2014 11:51 AM
roofer
10-15-2008 06:45 PM
Quick Reply: Removing Pro Pipe Baffle?
