Strong gas smell from exhaust
I’ve been having a problem with my 05 Road King and I’m not sure what to do next from a troubleshooting standpoint. About a month ago I started getting pops from the exhaust. The bike started to idle a little rough but it still ran fine. The problem has progressively gotten worse to the extent that I can smell gas when the bike is idling and it backfires every time I shift gears. I haven’t done any mods to the bike. I’ve changed the plugs, wires and coil. A friend said he thought it was the crank position sensor. I didn’t think that was the problem but I changed it anyway. It didn’t help. Does anyone have any ideas as to what the problem might be? Could it be a bad injector? The bike isn’t fun to ride in its current state. I will only take it to the dealer as a last resort so I’m hoping someone could give me some ideas as to what to look at next. I don’t want to continue replacing parts until I have a good idea as to what the problem is.
Thanks in advance for any comments / advice.
Is there an easy way to check for intake leaks? Would spraying soapy water on the exhaust manifold be a good way to check for a leak or is there a better method?
Yeah, as posted. Something flamable like brake cleaner. let the bike idle. Whe you spray around the intake manifold at its joints and the bike revs up on its own, then there is a leak. Exhaust you can check their tightness (torqued to spec, 120 inch pounds on the nuts to the heads) as an easy start.
Adam
Adam
Location: Western Illinois, land of bad roads, and corrupt politicians
