Trouble With a Used Road King - Power Loss
I don't see any spray in the tank and I did some riding today and all seems well. The only thing I noticed is a little drag between 30-35 and If I shift early or ride hard it's not noticeable. Still have the pops on decel. but I hear that's quite common with the SE pipes.
It's still going in to service for the SE Comp and the P0151 but I'm riding and right now that's what matters! Thanks guys if service gives me anymore info I'll update the post.
Chris
Chris
Ok so it's back from service the SE compensator got rid of the grinding and it rides a lot smoother. They greased all the connectors but couldn't find anything wrong with it. I've ridden about a hundred miles and all was good until tonight. Rode about 40 mile 50-65 MPH slowed to enter a freeway and on the ramp boom loss of power, once I got it up to speed huge surges in all gears. Couldn't hold the bike at 60 it jumped between 55-65.
The one thing I asked the shop to fix was the popping coming from the pipes. They are the SE pipes so they told me it was normal. From reading you can tune the pops out, but service won't do it and I understand why. I had thought that the rear cylinder was lean because it's the only one popping and it's got true duels. Now I'm thinking I have a bad plug in the rear cylinder it would explain the dropouts, surges, and pops. It pops at idle as well as decel and the left side pipe smelled rich when I stopped compared the the right.
What is average milage on a set of plugs? I ordered the cables and software for my tuner just in case but could this simply be a bad plug that gets weak when it's hot?
I really hate to take it back to service if it's something this simple.
Chris
Chris
Might be on to something here...when I dug my boat out this spring it ran like crap...loss of power, couldn't reach top end. Tore everything apart, cleaned, new filters. Same crap. Took injectors out and had them cleaned/serviced. Saw an improvment. Plugs looked good but they were about the last thing before taking it in to a dealer. New plugs, , success...run like a raped ape. The old plugs looked good but new ones cured the problem, so just because they look go don't assume they are.
I'm pretty sure I've got a good shop, it could be that they're just too busy this year. I've run several tanks of gas though it and some injector cleaner. I don't have codes anymore but still have lack of power above 25% throttle and pops on shift and decel. I have it scheduled for a tune at another shop this week so I'll see what happens then. Thanks for all the suggestions it's been quite the experience, next time I'll buy new.
On my way to PA the king crapped out. Backfiring loss of power etc. Managed to get it to a shop in New Castle where they seem to have resolved my issues. Bo tune but a new fuel filter o-ring seems to have fixed it. It was pinched causing a loss in fuel pressure. Funny something so small was such a big problem. Two months of searching but I think it's been solved. Thanks to all of you who took time to help me track this down.
Red89
06-29-2015 02:55 AM
