Looking for oil cooler
Call the guys at Jagg. Jagg used to make the H-D coolers but not any more. Go to the Jagg website and look around, then, if you need more information, call Jagg. Basically you have two choices, a vertical mount on the down tube or a low mount down near the voltage regulator; 10 row and 6 row, with or without Tstat.
I just installed the Jagg 10 row oil cooler and it has really helped with the heat! Previously I had the HD premium oil cooler but the O2 sensor was hitting the adapter. That was because of the Rinehart TDs.
Between the two, I would say that the Jagg is VERY easy to install and no worries about interference with the O2 sensors.
Do not buy the Ultracoolfl , the idea is good but their quality is not , they have had several issues I will not get into , call Jagg (quality product) talk to Marv Beals , Jaggs fan assisted unit is done , he is waiting on the mounting brackets to arrive any day now and they will be for sale , retail will be around $375 + the oil filter offset bracket , you can get one with or without a thermostat
