Looking for oil cooler
Old 07-29-2011, 11:28 AM
kmayHD's Avatar
kmayHD
kmayHD is offline
I run the Milwaukee Twins Dual Cool, A-Frame style cooler, with the Jagg 4600 twin cam adaptor(with anti rotation device-its a MUST). The cooler isnt as effective as the radiator style, but it very sharp looking and does considerably reduce the oil temperature. The Jagg adaptor is a breeze to install, just note the position of the Anti-Rotation bracket, because you have to install the inner plate of the adaptor first, then put the outer plate on which holds the Anti rotation thingy.
  #42
kmayHD's Avatar
kmayHD
kmayHD is offline
Also had some nice Stainless braided lines made with JIC fittings for the install. Very sharp, but a little pricey.
  #43
Old 07-29-2011, 12:44 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Originally Posted by FLHTCU Owner
I would talk to Jagg personally, with the thermostat question. I'm assuming they didn't recommend it due to the person's location, which was central Texas. Down there, (and in the hot climate states) you probably don't need a thermostat.
I ride in cold weather below 30 degrees sometimes. Marv at Jagg still said I didn't need one.
Their website in the FAQ says they are not needed.
Harrisment
07-21-2019 11:51 AM
Born2cure
07-22-2012 07:25 AM
z71_fourwheelin
10-18-2011 01:36 PM
Deer Stalker
07-06-2010 02:58 PM
Skip
04-11-2008 03:44 PM
Quick Reply: Looking for oil cooler
