Audio Upgrade - Hawg Wired Double Shot w/ZX Series Speakers (Part # PSC/ZX)
Greetings Gang,
Thanks for all the feedback and helpful tips. Special thanks to Frank at Drago’s Bike Works! After many many weeks perusing the site and gaining some varying tips and opinions for an audio upgrade, I opted for the 150W Double Shot package from Hawg Wired. I wanted to stay as far below a grand as I could, and get the most out of my 2-speaker setup on the bike.
I felt I could handle the install myself, to save some duckets, and will advise anyone else considering the job to ensure you have a decent shop, a variety of tools (including a hammer!), and some patience and problem-solving skills before approaching a project like this. It is not a quick “plug-and-play” scenario, and will take the part-timer a full day, if not that and some change.
Almost everything you need comes in the kit from Hawg Wired. I added connector ends for the speaker leads where they mount to the amp. (they weren’t included) All else was there in the kit.
Challenges:
First was studying the bike (2009 Electraglide Classic) and how the wiring ran through a box-channel beneath the gas tank, from the battery to the fairing. It took some thinking to get the amplifier power cable run through this channel, but it can be done. This saves you from worrying about it getting too close to the engine and overheating, even though they do include a heat sleeve for the cable. I did remove the tank mounting bolts at the rear of the tank and propped the tank up about 3 or 4 inches to aid in accessing the wiring channel. The top of the channel will come loose and raise up as well aiding access. I used a steel fish-tape to help in this process.
Second was grounding to the frame. My bike did not have a screw in the frame where the instructions indicated there would be one. (holding a bracket for a primary wiring bundle) Instead, the wiring bundle bracket was riveted to the frame. I drilled out and removed the rivet, then tapped the opening to accept a threaded screw. (chrome of course) I reinstalled the bracket along with the amplifier ground wire with the new screw. Nice and secure! (see what I mean about tools?) If you don’t have a tap set, use a hardened steel bold that has the same thread pattern of your finish screw.
Third was reusing the horizontal support brackets. If I understood the directions, they indicated their removal. However, I didn’t care for the idea of not having the support so I chose to do a little “light fabrication” on them. (this is where the hammer came in handy!)
On with the show:
Once I navigated the challenges, it was a fairly seamless installation. Stock speaker removal and the installation of the new speakers were straightforward. Removing the connectors from the lighter and the speakers was more difficult than anticipated, but don’t give up and don’t use too much force. My tip here is to try and work the connector on both axis a little bit while applying pull force. The lighter connection turned out to be the toughest. Do be careful here, the connector strength is more than the sub-materials and you can easily destroy your lighter or stock speakers. (if you care)
Once I had everything staged in place, and wired up, I ran several tests and adjusted tuning. Then, I tore it all down and reinstalled it in the permanent setup, with wiring all routed and dressed in proper and affixing the Velcro pads as instructed.
Results:
I have to say I was impressed with the results. At first, I was a little nervous as the sound was quite different than anticipated, but that was before proper tuning tasks began. Also, realize this system is a more ‘accurate’ representation of the recording. (thus the requirement to use a mastered, or store bought, CD for tuning, not the radio or a MP3) This system will bring out the weakness in some MP3 source files. J
The sound from this package is much clearer and cleaner. The range of sound is much deeper than the 20W stock system. An unfortunate after affect of the upgrade is finding out how weak some of my MP3s are. The old system apparently masked them, and that might be why I always thought the sound was tone shallow. With the new system, I swear I can hear the guy’s fingers letting loose of the guitar strings on some acoustic pieces in addition to the notes themselves. What this system is not is a chest-thumping bass box. (it's just a 6.5" 2-speaker system after all) However, on good sources, there is plenty of bass.
Don’t be in a rush to put your fairing back on until you have tuned and tested both inside your shop or garage, and outside. By the time I hit the rack Friday night my ears were screaming. I had been tuning inside the garage and, of course, maxing out volume on several selections. (my neighbor advised the following morning he was well aware of my adventures past 10:30 the previous evening and I had my garage door closed!) I finished up my tuning outside in the driveway the next morning. (much to the chagrin of more neighbors I’m certain)
Your final challenge might be in the tuning department so take your time – as individual preference is probably all over the place on Frequency and Gain settings. I opted for a Gain that was inside the recommended ‘standard settings’ and a Frequency that was somewhat less than the standard range. This amp will overpower these speakers, so don’t jack your Gain to the max (except for a minute just to have some fun) – it only causes distortion and gives you a tin-box sound.
I am very happy with this package. For the kit, and cost, it is a very nice system.
Thanks again for Frank’s help in providing the product. Time for a road trip!
Photos along the way and before-and-after videos can be found at: http://www.photoshop.com/users/carters/albums/7e10432c8c9b4b4f92458cf2d0854b6d
Cheers!
Challenges:
On with the show:
Results:
Cheers!
BubbasHD
Audio Systems
05-07-2013 12:58 PM
