amp and speaker compatibility....
Very confused with the amps thing. I have biketronics Titan/ hertz 6.5" speakers. They say they are rated at three ohms.
I am looking at the two channel Titan amp or the hawgwired dsc 1202 and want to make sure it is all compatible.
The amps say 4ohm speakers.
Was also looking at the arc min bx so out of the three are they all a good match for these speakers?
Thanks
Thanks
Very confused with the amps thing. I have biketronics Titan/ hertz 6.5" speakers. They say they are rated at three ohms. I am looking at the two channel Titan amp or the hawgwired dsc 1202 and want to make sure it is all compatible. The amps say 4ohm speakers. Was also looking at the arc min bx so out of the three are they all a good match for these speakers?
I can't imagine these amps couldn't run safely at 3Ω, but I would check with HW first and make sure they'll support them in that environment. I just bought an Elf amp on Ebay (refurb) for $135 and it works fine and fits well on top the head unit. It produces 75W @ 4Ω and 125W at 2Ω. Actually, I'm considering the Hertz speakers like you have, as the HT 5¼" aren't quite cutting it. So what is your opinion of them?
You might look into the Arc or Elf, as a number of riders have bought these, used them successfully, and I've heard no negative reports on them. They have ample power for most needs and can handle different speaker impedances. There are several recent threads on stereo upgrades here, one of which I started only last week.
