Ultra tour pak on 05 RK ?
Old 06-29-2011, 05:15 AM
Just Dave's Avatar
Just Dave
Just Dave is offline
Originally Posted by Mr.Biker
About five years ago I purchased a detachable tour pak from a 99 Ultra on EBay to put on my 02 Road King and I asked my local HD dealer the same wiring question. The dealer informed me that it could not be done. Determined to prove them wrong I researched many options and I finally went with Ride Time. I bought the Quick-Connect Accessory and Trailer Wiring Adapter and the RTQC Quick-Connect Universal Wiring Harness and without cutting any wires, I had the tour pak wired (and still detachable) within an hour.
That sure is aggravating when the dealers will not put any energy into helping you do something that is not in the book. I had one refuse to help me find a clutch cable that would work because I had changed the bars on a Sporster and the "one in the book" was not long enough. I suggested we could just hold the one I had in my hand up next to the ones he had hanging there in stock and he refused and threatened to call the law on me. LOL, I was kinda irate at this point but dam...
OP, hope you get it on there, seen a bunch of them so I know it is possible.
Old 06-29-2011, 09:07 PM
Doc o's Avatar
Doc o
Doc o is offline
Thanks for the help.
I'm going with the Ride Time. Very simple.
I do want to find the correct 3 prong plug that plugs into the pak.
I think J&Ps has them.
The parts girls at the dealer did try to help but I think when the techs run into something
not in thier manuals they're stumped.
Old 06-29-2011, 09:46 PM
Mr.Biker's Avatar
Mr.Biker
Mr.Biker is offline
My tour pak lights (the side lights) had the female end of the RTQC Quick-Connect Wiring Harness on it when I bought it. I believe the connector is a 2-place Deutsch or multilock Connector (as seen in my service manual) so I was able to plug into the male end of the connector that I wired to the Quick-Connect Accessory and Trailer Wiring Adapter. When installing the RTQC I made sure that the connector was just inside my tour pak (there was a wire access hole in the bottom of the front left side of the pak) so I can still disconnect in seconds.
In my research I noticed that some tour paks use 3-place multilock connectors so you may need one of those if your pak has the side lights and the rear lights.
Big trucker
08-19-2016 09:09 PM
Earnie1200C
07-18-2011 05:10 PM
WoodyHD
09-16-2010 03:52 PM
jimmie d wad
07-02-2010 08:22 AM
electra glide
04-11-2009 05:59 AM
Quick Reply: Ultra tour pak on 05 RK ?
