Clutch cover bolt backed out
I just need a quick remedy for what I hope is an easy fix. One of the bolts on the clutch cover of my 05 Ultra has gotten loose. On almost any of the bolts it would be simple - remove, blue loctite, replace. Unfortunately, of course, it has to be the bolt covered half way by the clutch cable! ugh.
So, I assume I have to unscrew the clutch cable from the housing to get clearance for the allen wrench (yes, I did consider just cutting off the allen wrench, but it does not appear that doing that would leave enough shoulder on the wrench to go into the hole to grip).
So my question is, do I have to loosen the clutch cable in the middle, like you do when swapping clutch levers (I'm all too familiar with that thanks to being graceful twice so far...yep, I did) or can you just unscrew it at the housing?
Thanks!
Thanks!
I don't see how your clutch cable could be covering one of the bolt holes on the tranny side cover. In fact, in order to change a cable, etc. you screw in the cable then screw on the cover. The cable goes into the side and should not interfere with the bolts. Unless You're talking about the black wrinkle bearing housing assembly itself and not the chrome tranny side cover. If that is what you are talking about, simply remove the tranny side cover with the cable in tact and tighten the bolt and reinstall the tranny side cover.
Comfortably Numb
05-03-2021 12:45 AM
fender187
05-10-2017 06:14 AM
