oil cooler???
Old 07-07-2011, 06:45 PM
swinestein's Avatar
swinestein
swinestein is offline
Ok Guy's I'm seeing a lot of smack talk but no real world data being thrown out... I'm wondering from those who had a oil temp gauge before installing a cooler, how much did it drop your temps (in the same conditions)? 10 degrees, 20 degrees, 30 degrees? Bottom line is I'm thinking about getting one however I'd like to know what I can expect to gain (or lose in the case). Thanks!
  #62
Old 07-07-2011, 07:30 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Gauge before the cooler, added a Jagg 10 row lowmount, 20 degree drop in like conditions.
  #63
Old 07-07-2011, 07:44 PM
DHubbs's Avatar
DHubbs
DHubbs is offline
Im looking at 30 degree temp drop with Ultra cool. This is in Ga. with 95 plus degree temps. The highest I have seen is 230/232 with a gauge.
  #64
Old 07-07-2011, 09:42 PM
Tomz1178's Avatar
Tomz1178
Tomz1178 is offline
6th Gear
hey Fabrik8r any idea how much the Fan assist Jagg will be goin for?
  #65
Old 07-08-2011, 05:39 AM
scottsk9s's Avatar
scottsk9s
scottsk9s is offline
Stage III
hey every one trying to keep there bike cool check out ultra cool fans im getting on for my soft tail my brother has one on bouth of his street glides hope this helps he swers by his check them out
  #66
Old 07-08-2011, 06:47 AM
tj316's Avatar
tj316
tj316 is offline
Marv at Jagg told me about $375 + your oil filter adapter which you can use one with a by pass thermostat $149 or without one $109 , I am sure dealers will give you a break once they get them , you can usually get 15-20% off through dealers
  #67
Old 07-08-2011, 07:01 AM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
I'm not sure what the price point will be for Jagg's Fan system. I can't imagine much more than 100 bucks more than a standard, but it's hard to say without knowing the manufacturer and specifications of the fans; they start to get expensive when they are built to high temp and waterproof specifications. The system will be user configured, so you will choose the adapter you want and pay acordingly. I am confident that the Jagg will outperform the Ultracool, been running my own Jagg based system for 3 years now and my results far excede the reports of the Ultracool users.
  #68
Old 07-08-2011, 08:03 AM
kevmiami's Avatar
kevmiami
kevmiami is offline
Have put more miles on my H-D Cooler (no fan) - note, I also put Mobile 1 in bike; I assume it was H-D's "standard" oil prior to that. In S. FL, I'm seeing about a 25 degree drop in temperature for 1-3 gear stop/go traffic while in mid to high 80s. I'm very pleased, my pre-cooler high temp in these conditions was 289 degrees (techinally still safe) but now I run 240-250 in these conditions, with 265 the highest I have seen. The bike ran and still runs 240s in hot weather at 65-85 mph in 5-6 gear (perfect temp).
My conclusion would be to avoid the complexity of fans unless you are doing parades or other extraordinary stuff. Even though there is no airflow in stop & go, the extra surface area seems to be sufficient to cool nicely. Cheers, Kevin.
  #69
Old 07-14-2011, 12:51 PM
tj316's Avatar
tj316
tj316 is offline
Uncle Larry my Jagg will be here Tuesday , I'm installing it and going on vacation , when I get back the HD one is yours if you still want it , let me know
Hey --- I've got a perfectly good trash can here in my garage .... AND .... I'll pay the shipping to put that HD oil cooler in it! Well ..... ???
  #70
Old 07-15-2011, 10:05 PM
slickrick_58's Avatar
slickrick_58
slickrick_58 is offline
Been running an UltraCool oil cooler for 1-1/2 years. Fan cooled and looks good too. They've gone up a hundred bucks since I got mine tho'. Definetly worth it in heavy traffic.
OldPhat
07-15-2023 11:16 AM
1957buick
05-04-2016 08:41 PM
easybiker
04-30-2015 12:16 PM
jackhis
01-15-2013 06:20 PM
smredlus79
06-20-2007 01:38 AM
Quick Reply: oil cooler???
