Power Commander V ?????
I have a 2011 Ultra Limited with a stage 1. The componets of the the upgrade are a screaming eagle A/C , Carriage Works 4" slipons (5800CB) and a power commander V. This was all put on at the local H-D shop, and dyno tuned. Power and torque are good, fuel mileage is in the tank 30-32 mpg. Here is the question. I hooked up the computer to the PCV and downloaded the Map. 70% of the Map shows 20-30% above stock. I think this is way to rich. Any suggestions? And before you start in on me, I didn't use Jamie, my mistake. I have e-mailed Power Commander and I am waiting on a reply. And after checking Power Commander's web site, the canned Maps they have do not include Carriage Works. I was thinking of loading the Rinehart Map and give it a try. Thanks for any help, let the flames begin.
just try this first. Save your map for future possible use and reference. Take your mouse, right click and shade the CRUISE area of your map,for example; the range from 2000 RPM at 10-15% throttle through your cruise range. Then hit your page down button 4-5 times maybe more if those numbers are really big. That will trim the shaded areas by -1 each time you hit the button. Go give her a ride. You can always go back.
I would recommend leaving the ignition tables alone for now unless it pings a lot.
Mark
Mark
HD shows 35 MPG city and that's just an estimate. I'm getting 38 and I do mostly highway driving. I'm hoping be be in low 40s after stage one and PCPV. But I'm still saving about $200 a month on gas compared to my truck which averages 14.7MPG.
I am not complaining at all about gas mileage ,my truck only gets abou 14 also so yes we are saving money
