Antenna relocation
my antenna just clears it to the side an inch or so... would only be in the way if whatever was on the rack overhangs it.. and when on rough roads etc it would brush the rack wearing the covering on it away... so a piece of rubber hose would be needed, relocate it or get a short flexible one from autozone.
for the little bit i'll be using the rack and what i'm carrying i'm gonna live with it myself... especially if a cloth bag etc is on the rack.. it won't wear enough to cause any damage
kinda hard to tell but it's not directly behind the rack. next to it...
hope this helps.. just happened to have this one on my phone. if needed i can get a better one when i get home.
Last edited by last12know; 06-27-2011 at 10:22 PM. Reason: next to the rack not behind it.. my memory of it was wrong.
When I bought my tour pack it came with the antenna relocation kit. I first mounted the tour pack with the antenna in the stock location just to see if it cleared and it did not. It wasn't even close. So, I moved the antenna to the new spot on the tour pack. After only about 5 or 6 moves between the locations while taking the tour pack on and off, the threads inside the antenna are shot and it won't even begin to mount anymore. I figured a new one might do the same, so based on other posts here I ordered the hidden antenna off eBay. It should arrive this week. If it doesn't work well, I'll buy a short antenna from the dealer and be very careful mounting it to ensure I don't strip the threads this time.
