Bike been running Great - won't start
bike's been running great - take a rest along the ride 2day then it just won't start back up. it's late now and iam wooped. the fuel filter was change little while back - seems like it may not getting fuel -I can hear the fuel pump charge up when I turn on the power - cranks - no startup
any suggestions where to start in the morning/
....its a 08'FLHRC
....its a 08'FLHRC
if you can get a volt meter, check your battery voltage at rest (no key in ignition). theres a big difference in state of charge and cranking ability. 12.25 volts is a 40% charge, and 12.7 is an 80% charge. So what to do if you find the battery voltage low, clean your batt connections, pull your batter out and have it charged up (don't jump start it, that could damage your regulator ).
if it has enough battery to turn it over it has enough to start it so go back to basics .fuel? you said you could hear the pump ...does it pump fast at first then slow down as it builds pressure ? pull a plug wire stick a screwdriver or any conductor in the wire and hold it close but not touching the head ...did it spArk ? did you get zapped ? either would indicate enough spark ... you need answers to these before you can go further
