Opinions of headers to reduce heat?
Hi All, I have an 09 Streetglide with the stock headers. I want to change them out because they are cooking my legs and the passenger on the right side. I have looked at V&H dresser duals, power duals, and BUB true duals. Does anyone have an opinion on whats the best option in turns of rerouting the heat?
Thanks
Thanks
Cool the heat with !
FULLSAC - ceramic coated headers worked for me. I have a 2010 Ultra Classic and tatooed my right calf the size of a silver dollar(if you know what that is) switched to the FULLSAC and added V & H Slash Cut Pipes with a stage 1, and had it Dyno tuned. Could not be any happier. Took out 85-92% of the heat!
Yes the ceramic may help a little bit but your 09 doesn't have a cat in it so I would say changing the head pipe is not your problem. Fuel management is. Unless you have done a stage 1 AC and some sort of tuner to richen the factory lean condition I don't think you are going to reduce heat by any noticeable amount.
+1.....ceramic headers (Fullsac, Jackpot, etc.) will help reduce heat a bit, but if you already have catless headers, I would recommend a fuel management system along with aftermarket slipons and a/c. A properly tuned Stage 1 should not run hot. My 2011 RGC came with a cat in the headpipe, so I had to gut it or get new headers. I chose V&H True Duals. With my full Stage 1, me and the wife don't notice bad engine heat anymore, and we've ridden up to 90 deg.
You do need a tuner it will help you out very much,all of the above info is right on..Something else that will help you out and make riding your bike comfortable in the heat is a crotch cooler..We are a sponsor here and yes we are the people that make them..If you do a search on here or Google you will find a lot of very satisfied customers about our products and customer service..Also please visit our website..Thank you.
Texas Fat Boy
09-13-2008 06:43 AM
