When changing switch on rear brake, does air really get into brake lines or is it just a chance for air? I'm trying to decide weather I want to do it or have moco do it. I do not know anything about how ABS systems work!
should not let air in , alittle fluid should come out but if you find it is the switch have a new one ready to go right back in , don't let it set with the switch out . it will drain the system
