rockford fosgate punch amp is out!!!!
I'm no guru, but what you probably are seeing are a pair of 2 ohm speakers wired in SERIES so that a 4 ohm load is created for one channel of the amp. That's fine as far as it goes, but it won't help you with your four 2 ohm speakers and the RF 4-channel amp since you'll only be using 2 of the 4-channels.
Said another way, SERIES wiring, in the example you are considering, simply puts two speakers on a single channel, rather than what you now have which is each speaker on its own channel.
Carl
Carl
That is exactly what I saw and you are correct. So this amp will not work for me having 2 ohm speakers looks like I am off to something else bummer liked the price and many other things about the amp.
Dealer in Chicago area told me he would have these in on Tuesday/Wednesday. I was going to buy this one but really don't want to switch out my 2 ohm Hogtune speakers yet.
Has anyone mounted a JL Audio XD400/4 amp in the fairing? It was not much more than this RF amp. Guess I could put it in the tour pack if necessary.
Mine
Mine is in the bike and driving 2 of the power series 6.5' shallows. Not done yet and outer fairing is not back on, but I put a towel behind them and it is pretty loud. I have nothing to compare it to, but if interested I started a thread about this long ago .
Kris.
www.hdforums.com/forum/touring-models/603943-new-rockford-fosgate-mini-amp.html
Kris.
Not sure where you are see the 3 ohm but on the hertz web site it looks like they only have 4 ohm speakers. I bought two HCX 165 from a hertz vendor and two BT 452 from biketronic and they were the same. I'm running the 4 HCX 165 with a arc amp and I'm getting great sound.
