I can't figure out how to install the Police solo seat on my 2010 RKC
Where does the air tank mount?
I bought a solo police seat from some nice people near Chicago and it came off a 2010 police Road King. It seems to have all the parts and I understand the seat pivot, etc but I don't see where the air tank can fit on my 2010 RKC. I tried to find a spot somewhere around the battery box but there's not enough room in front of the battery because of all the wiring harnesses.
The length of the air tubing (about 18") made me think the air tank might fit somewhere farther away but I don't see any blank holes that match the spacing of the mounting bolts on the tank.
The air tank was mounted under the radio box mount that was located behind the seat. The mount is the same as the tour pack mount. I had my police seat for a while and relocated the air bottle to the saddle bag. Pretty easy, just cut a small notch for the air line and tape the bottle to the inside of the bag.
Some guys relocate the tank to inside one of the saddlebags. If you place the tank beneath the right side cover, you might have to remove the gauge from the tank. The gauge isn't necessary, and after awhile, you'll be able to add air just by feel.
You probably wouldn't want the tank located in the original location. There's a reason (ugly) why so many guys move that tank, even if it means giving up space inside a saddlebag.
There was also a post many moons ago where a guy mounted the tank between the saddlebag and the fender on the right side. Presuming you have the dual-rail saddlebag guards (Ultra & Police style), if you look where the two rails are bolted to the bike, it was there that he mounted the tank. Pretty clean I remember. He may have mounted them using Adell clamps.
Even though I also removed my Police seat set-up from my '09, I have to admit, it was THE most comfortable seat I've ever ridden on. Riding for hours felt like riding for minutes.
Good luck.
Good luck.
