The only adjustment I'm aware of, is there are 4 screw holes (2 on each side) that go through the bottom of the TP. You can move the TP to the other set of screw holes that will move it back about 1" (if it's currently using the forward holes). Remove the liner and you'll see the holes. Otherwise, you'll have to get a TP relocation kit.
