Power Vision question
I just bought the Power vision.
From my understanding it is coming unflashed?
I was looking at the power vision web site and didn't see a flash with the AN big sucker and/or the V&H moster rounds I'm running.
Do I just use the S/E and V&H ovals? Do I reinstall the O2 sensors?
I'm currently running with a Daytona Twin Tech II (with sensor eliminators) I have it set as per the instructions and don't like the way the bike runs.
My next step was either a dyno tune or the power vision.
I choose the power vision because everything I read leads me to believe its a way better tuner and easier to tune with.
Any suggestions or advice would be appreciated.
Thanks
Thanks
The Power Vision "flashes" your bikes ECM with the chosen map for your set-up. Fuel Moto has an extensive map library and sends their units out pre-programmed, but if you went ala carte' with Dyno-Jet you will have to make due with one of their canned maps that is close, and likely a dyno-tune to get there.
Mark
Mark
gant
08-16-2012 11:35 AM
