sealed battery - not - heat from engine will dry out your battery
I know, I know, I didn't use HD battery acid so the battery will eventually blow up......Its a standard 6 wet cell battery. Like most sealed wet cell batteries, the assumption is that the vent cap will condense the acid before the gases from recharging escape and the condensed acid will drain back into the battery. Problem is that condensation process is pretty difficult when the battery is co-located with an engine operating at almost 300 degrees. The battery took a charge real easy and passed the load test with no problems. Cranked the bike right up.
I work in the battery industry (UPS batteries) & if you know what your doing you can add acid to a maintenance free AGM battery. In fact in some conditions this is standard in the industry to avoid replacing them prematurely under warranty.
The key is to not completely seal that cap, because it is actually a pressurized one way vent cap, usually calibrated to open (vent) at a set PSI.
So if you get a few more weeks out of it while your waiting on you new one to get here, more power to you - don't listen to all these other mis-informed people.
Please get your facts straight as this type of information is very misleading.
No guy, it doesn't matter if it was HD battery acid or any other brand. You don't add acid to an old battery, you add distilled water.
