Yaffe Stealth 3 Plate mount installed
as promised here are the pics..
i wanted the lights set back a bit, so i took some flat aluminum stock and curved it to the inside of the facia enough to use some 2 part epoxy to adhere it to the facia
after that was done i took another piece of aluminum stock to make the mounting surface flush with the edge of the facia.
i have it so the plasma rod plastic tube piece is out above the edge of the facia.. turned out really nice and clean.
all pics are from my iphone, so quality might not be the best in the world
i took pics so you could all see how i mounted them.
the mount i made
and here is the mount with the plasma rod installed
and lights on no brake applied
lights on brake applied (doesnt look that different in pic but it is)
lights out no brake
and with brake applied
the mount i made
lights out no brake
