2005 Road King Classic primary leak.....
OK, showed some pictures a little while back, figured I had a leak from the shifter shaft seal. I pulled everything apart, replaced the shifter shaft seal when I noticed leaking from another area. The bike has been apart for about a week while I was waiting for my shifter shaft seal, and when I went to work on it tonight, I noticed a couple of drops of fluid on the floor under the drive sprocket. I also noticed some fluid built up in the lip on the sprocket itself. Looking closer, I see a build up of fluid dripping from the sprocket itself and a drip ready to drop fro mthe bolt right below the sprocket. Please see pics. Looking at the service manual, I really dont know what seal this would be. Any ideas? Point me in the right direction. Thanks.
The General location:
closer of problem area:
The quad seal requires the complete removal of the pulley? This is when I need the crazy priced tool from Harley correct? Could be both main seal and quad seal right, since I am seeing build up on the pulley itself, as well as behind the pulley on the backside of the teeth of it the pulley and the bolt hole.
