Good Cam Change Video
Old 06-20-2011, 06:24 PM
Glyder's Avatar
Glyder
Glyder is offline
Default Good Cam Change Video
Looks like a pretty simple deal to do in an afternoon.
http://www.youtube.com/watch?v=n5KvamRqCis
Old 06-20-2011, 06:35 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
Cool I watched 8 mins of it. you have to appreciate the effort even tho I have done this I will watch it when I have more time.
Old 06-20-2011, 06:59 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
lots of special tools
Old 06-20-2011, 07:53 PM
Glyder's Avatar
Glyder
Glyder is offline
You can rent the bearing puller at Autozone and reinstall it using the old cam.
Old 06-20-2011, 08:55 PM
mrmud4x4's Avatar
mrmud4x4
mrmud4x4 is offline
Excellent video.....I'm less than a month from doing my cam plate tensioner upgrade along with new cams.
Thanks!!
Old 06-20-2011, 09:04 PM
CaptainK's Avatar
CaptainK
CaptainK is offline
Wow great video!!!, all 57 minutes of it. Great tool for anyone thinking of doing a cam swap or cam guides.
Old 06-21-2011, 07:36 AM
iclick's Avatar
iclick
iclick is offline
The only special tool needed is the bearing puller/installer.
Old 06-21-2011, 08:37 AM
Mike's Avatar
Mike
Mike is offline
There are a couple of tools that I like to use, but they aren't necessary. I just like having the correct tool for the job. The little key that fits between the pinion sprocket and the cam sprocket to lock the motor down can be picked up on ebay for about 15 bucks. If you're pulling the pushrods out through the top of the motor, there are two wrenches, one for the rocker box covers, and one for the lower rocker boxes that are great to have, because of the tight spaces involved.
You can tap in the inner bearings with an old camshaft, or you can buy the tool that presses them in. It's done both ways, I'd recommend pressing them in, but lots of guys have just tapped them into place with no apparant problems.
Old 06-21-2011, 08:45 AM
reh13's Avatar
reh13
reh13 is offline
Should probably be a sticky...perhaps in the tech forum.
Old 06-21-2011, 09:15 AM
Hydroboy35th's Avatar
Hydroboy35th
Hydroboy35th is offline
great video!, are they gonna do a big bore video soon?,lol
Quick Reply: Good Cam Change Video
