Good Cam Change Video
Old 06-21-2011, 07:02 PM
iclick's Avatar
iclick
iclick is offline
Originally Posted by mrmud4x4
When they get pressed in using a plate it squares the sides for smooth, even placement that also allows proper depth of bearing easily.
When they are tapped in, there is a chance that they may be driven into the bore unevenly or not square....possible damage to the bearing seat/race and/or bore.
I've pressed bearings in and tapped them in....just have to make sure they are square along the sides(clean too) when doing it.
(whatever tool you use...don't want to tap against the bearing *****/rollers either)
That's what I thought, but with the way the Beatty tool is made I'm not sure you can avoid putting them evenly or squared. It's also cut so that it stops at the right depth.
  #32
Old 06-21-2011, 07:10 PM
mrmud4x4's Avatar
mrmud4x4
mrmud4x4 is offline
OK...peaked my curiosity.....got to google this Beatty tool now...lol
  #33
Old 06-21-2011, 07:26 PM
mrmud4x4's Avatar
mrmud4x4
mrmud4x4 is offline
Here's the Beatty tool.....This thread is really help'n me out....thanks!
I'm getting one!!
check below thread out....
https://www.hdforums.com/forum/touri...er-tool-2.html
  #34
Old 06-21-2011, 09:36 PM
ElectraHead's Avatar
ElectraHead
ElectraHead is offline
great read
  #35
Old 06-21-2011, 09:58 PM
Teardrop's Avatar
Teardrop
Teardrop is offline
I beginning to think I could do this...
  #36
Old 06-21-2011, 11:58 PM
1931jamesw's Avatar
1931jamesw
1931jamesw is offline
Subscribed.
  #37
Old 06-22-2011, 12:26 AM
myred55's Avatar
myred55
myred55 is offline
Great video, thanks for sharing!
  #38
Old 06-22-2011, 01:22 AM
mike5511's Avatar
mike5511
mike5511 is offline
Figures I would find this AFTER I did my cam install!!!!! And I'm NOT gonna watch it either!!! Mine runs great as of right now, about 500 miles since cam change. If I watch this and find out I did something wrong, I'll worry about it so much I'll probably "will it" to mess up!!!!
  #39
Old 06-22-2011, 01:46 AM
traveler's Avatar
traveler
traveler is offline
you could do this without even changing the bearings if you only have a couple thousand on the motor and still be fine.
~Joe
  #40
Old 06-22-2011, 02:10 AM
Glyder's Avatar
Glyder
Glyder is offline
~Joe
Yep. Im sure the dealers dont change them out for guys that get them done before they take delivery on them.
Quick Reply: Good Cam Change Video
