Spark Plug Heat Ranges
I use to drag race with a big block chevy and ran a ton of NOS. I would run differant heat range plugs and differant gaps to make all 8 cyl as close as posible. I did same thing on my 10 WG I am running the NGK Iridiums front one step colder at 35 and rear at 50. The front was to lean with stock plug and pinging and now no ping and runs a little cooler and revs a little faster. I watched a you tube video of a guy dyno a Harley and change to NGKs and it made 3 more h.p.
Wow, of all the things I found, since all my stuff has been shipped off. I still have my original spark plugs. I think someone earlier may be onto something about running two different plugs. I have one plug that is a very nice light brown and the other plug has a white deposit build-up, almost a blistered electrode look. I think the later plug was from the aft cylinder, I failed to mark them. Maybe a stock plug up front and a cooler plug in the aft cylinder. When I get home tonight, I will take some pics of the plugs and post them.
Cale
Cale
Correct. The wrong resistance plug can creat havoc for the ion sening as it relies on the correct voltage. It will not hurt your engine but it causes "false knock retard" which will pull up to 8 degrees of timing. Over time the adaptive knock retard table will remove most of the timing. Only thing that will happen is your bike could loose some responsiveness and "may" see increased engine temps. Vrod plug is one step colder.
Cale
Cale
Let me know how the Autolites work for you. I'm running HD Gold now, mostly because I had trouble with the screw cap on the Autolites that I mentioned earlier. When I ran the Autolites I had no way to check knock retard, but I do now with the Power Vision. I can say that at that time I was setting the advance in the cruise range by ear, and knock retard was working. If I went back to the Autolite I would probably solder the caps on.
