auto tune for the power commander??
IMO, I would use the correct PC for your ride and then get the correct map for your mods.
If its not listed then contact Dynoject and they will email you the download thats right for your set up. then your ecm will adjust from there.
imo, the auto tun will get you close, but not dead on...
again jmo....
again jmo....
It's good to have if you have a good map already, but like to change things a lot, it'll tune itself back in pretty quickly. If you're looking for that very last HP then a Dyno would be the best bet, but for 98% of the riders who just change exhaust, air cleaners and other small things around a lot then the Auto tuner is a pretty good thing, just my 2 cents though.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
I have Autotune and I like it.
It allows me to make changes without having to worry about getting a new download to compensate.
I had the AFR tables set by a local tuner on a 250i to get optimal HP and torque, saved that map, and then adjusted it to make a new map that was a little more lean in the cruise range but still retained power for acceleration.
And I like the ability to connect it to my netbook, pull up the tables, and make changes whenever I want.
Today, I tinker with my map manually if I want to change something (like if I have popping at decel or pinging at acceleration but I hope if I connect my PC-V to an Autotune module, the updates will be done automatically. Am I correct?
I have a PC-V with the Autotune from FuelMoto and can tell you it is a great tool. FuelMoto gave me a map that was real close. I let the Autotune do it's thing for a week of riding. I accepted the trim once and since just run in the Autotune mode. I accepted the trims so the FuelMoto map would be more accurate if something in foreseen happens to the Autotune module or sensors. I'm tempted to play around with the AFR in the cruise range for that little extra mpg, but the bike runs so good I don't see the need.
I have a PC-V without Autotune and I'm curious to know how it works. Do you have to update the map from time to time to include the mods suggested by the Autotune module or can you just set a target AFR and have the Autotune update your map continuously?
Below is the target AFR table for my bike. If you look to the device tree on the left, you'll see where the Autotune has inserted itself and that there is an AFR and trim table for each cylinder.
Since I have specified 13.2 at 40% throttle for cylinder one, it will trim the cylinder one fuel table to achieve it.
If you have popping and pinging and you believe it's an AFR issue, you can easily adjust the AFR's to try and tune it out, but it's only going to do what you tell it to.
Well, there's supposed to be an AFR picture here, but anything large enough to read is too big to upload.
I have a pretty basic understanding of Autotune. Others on the board such as IClick have a much better understanding and would be able to more fully explain all the functions and capabilities.
Did you have the bike dyno tuned? If so, why not just run it as is? OTOH if you like to tweak and/or plan on doing further performance mods to your bike, it would be a cost-effective way to maintain an accurate tune.
again jmo....
again jmo....
