RKC Bullet Turn Signal Kit 68615-04 Install ??'s
Hi, Has anyone installed the HD Bullet 68615-04 Rear Turn Signal Kit on a RKC and made it work as a Run/Brake/Turn(RBT) setup?
I bought the 68615-04 yesterday from the local HD shop, but I seen that the bulbs have a single contact on the end (single filament), so not sure I can make them RBT, cause I thought you needed the bulbs with two filament contacts? I haven't tested yet, but think the kit is designed to only work as turn signals???
Currently I have the Panacea LED flat turn signal kit and the load equalizers all they way around the bike that work fine, but wanted to change the look a bit, so the Panacea lighting will all come off and make way for the bullet setup.
Input appreciated
Input appreciated
VinnySem
10-08-2010 10:40 AM
liboozers
06-04-2006 12:08 AM
