Polk MM 6501 components ROCK!
i just got done installing a set of Polk MM 6501 components in my street glide.
i previously had a set of J&M 5.25 hi performance speakers
and a 200 watt amp..
well those were just not cutting it.
my buddy had installed the J&M 7.25 rokkers and 250 watt amp in his street glide and the sound was ok, but i was looking for more.
i have found it!
the Polks deliver crystal clear highs and great bass for being in the fairing
i mounted the tweeters in the top gauge holes, i eliminated the volt and air gauges and moved the fuel gauge to the bottom hole.
i have the crossovers mounted on top of my amp, which is just enough clearance
i also installed some foam in the fairing which i think helped a bit as well
i just cant get over how great these speakers sound.
i had my buddy (the one who has the J&M rokker setup) over and he was blown away at the sound..
if your looking for a quality setup definately take a look at the polk mm 6501 components. they are 2.7 ohm and you can find them for around $180
pics and video to follow
i have found it!
HWill
Audio Systems
55
04-18-2019 01:18 PM
HogPilot54
Audio Systems
08-19-2018 08:27 AM
