XiED ViED 105 NOT GOOD
i wonder why my stage 1 down load on my 2011 rgu shows richer then stock and richer then my tts mastertune? I asked Steve cole owner of tts why this was and he said that harley could make them as rich as they wanted as long as they were epa at idle. i have posted the stage 1 lambda map here before as proof and everyone refuses to believe it is from the sepst street legal down load but it is.
How many miles does it take your ECM to adjust to a new exhaust or air cleaner? Exactly, your factory ECM does not learn, that would make it an auto tune system. Not sure what happened in those 200 miles, but it wasn't the ECM adjusting to the false O2 signal your VIEDS were sending.
When the 02 sensor bias voltage changes, the ECM attempts to adjust...hence the richer AFR. The 200 miles was from 2 sources; Jaime at Fuel Moto, and my personal experience.
Cheers...
My dealer was the one who told me the Stage 1 download by itself was a ripoff. It doesn't change AFR in closed-loop, i.e. idle and steady-state cruise, because it has to remain EPA compliant. So, the engine runs lean & hot, just like the stocker. While I don't doubt your experience (every engine/ECM can react differently to the same mod) it is rare that anyone says the Stage 1 d/l by itself cooled the engine, and I've never heard anyone say it made the engine run richer than the TTS. The forums are full of folks saying it did nothing and are looking for alternative methods to richen the AFR. I have to ask- if the Stage 1 richened your AFR as much as it did, why drop the coin for the TTS too? (Not trying to be nosy, just really curious...)
Yes I put on little over 5 hours of riding time, train of thought is that any engine modification takes 2 - 4 hours for the ECM to learn - on a Harley.
Having the mountains to play in is a big help....
I belive that a ECM that has 16 bits or more can learn in 1 hour of real time riding..
My Motocross bike has a 24 bit ECM and takes 6 laps to adjust...
Like I said, these made the bike Loose Low end power, from a stand still to 20 MPH...and I adjusted them, made no difference...again no codes enegin RPM's were perfect etc...........
here is the hd stage one arf/lambda map
The stock ECM doesn't adjust to an air cleaner or exhaust...since the O2 sensor bias voltage remains unchanged while in closed loop.
Cheers...
Cheers...
