Damn drip
Damn drip
I ride an '09 Street Glide and after the 1,000 mile service it developed a drip. One drip only but it happens everytime I shut down in the garage. Levels stay good on the fluids and the bike runs great. The little spots drive the wife crazy and I have not been able to find it.
Based on the color I believe it is oil (I use redline in the tranny).
Any advice on where to look would be appreciated.
I do my own services and yes, I have a manual.
Thanks!
Thanks!
I'm thinking there's oil uder the engine from removing the filter, we all know how sloppy that can be. I would make sure to clean around the filter area on back and down with something like S100 so you can spay it and let it run wherever the oil may have run, rinse and let dry before putting her back into the garage. Then check the filter tightness, drain plug o-rings and primary gasket for any oil. If all's good with them I would check the oil swith area and the shifter lever area, they both have been known to leak at the seal.
Thanks guys. I should have mentioned that I just did the 15K service and the leak has been going on for the past 14K miles. I will check around the seals and oil switch again. I clean under the motor with brake cleaner pretty thoroughly and just replaced all of the o rings, so it is probably leaking at a seal.
Doesn't bother me too much but the wife is a neat freak.
Thanks!
Thanks!
One thing I forgot to mention, HD has a problem with jugs seeping right thru the jug itself. I had that problem on an '08 Super Glide. Seems the jugs are "pourous" and you can see a drop of oil here and there for no reason, and no matter how hard you look at the jug it appears fine. HD replaced my jug in 3 hrs. and never had a problem again.
Feel the bottom of the air filter with your finger. If you fell oil, your drip is as a result of slightly overfilled oil which gets sucked into the intake thru the case vent lines that route into the intake. There's also two o rings for the main intake mount bolts which sometimes seep oil. Make sure these were installed with lock tight
