Street glide run turn brake light on a limited
If you are referring to Bullet Rear Turn Signal Bar Kit #68615004, the 2011 P&A catalog says the following:
Give your bike a new sporting attitude with the Bullet Turn Signal Kit. The chrome-plated bar and bullet turn signal housings provide a custom look, and the narrow profile places the signal lamps between the saddlebag and the rear fender for a sleek appearance.
68615-04
Domestic
Fits '99-'08 Touring models (except FLHX), '09-later FLHRC, FLHTC, FLHTCU, FLHTK (Original Equipment on FLTRU), '99-'08 FLST and FLSTC Softail® models. Will not fit FLSTC models with '00-later Original Equipment Heritage Classic Saddlebags.
68615-04
Domestic
68615-04
Domestic
68615-04
Domestic
Not the Street Glide one though, but the one Harley makes without the license plate light.
Mark
I could do that one, But I am wanting to know if anyone has mounted the street glide bar . I want to clean up the back, but I am as interested in relocating the license as I am replacing the turn signals
Got it! Should have gone to the garage and looked before typing. Anyway, I did just take a look at my 08 SG and 11 Limited. Looks like both light bars mount with two bolts inserted from the back of the fender into the light bar, and the SG has an additional bolt through the fender under the integral license plate bracket. A rough measurement shows the top bolts about six inches apart on both bikes. No hole on the limited for the 3rd bolt but drilling one is an option. I'm guessing the SG bar will fit with the 3rd hole drilled.
Was planning on adding the 68615004 bar to my limited, but as you say, plate will stay under the tour pack...
You could also get a lighted aftermarket frame, end of problem.
https://www.hdforums.com/forum/touri...n-signals.html
Mark
There is one in the classified section for 130.00. He posted great pics and it looks like it will mount fine. It won't be run/turn/brake like the street glide unless you have that module installed,which is available. All I can see is you will have to lengthen the license plate light wire. (maybe, it may run off the running light circuit). But you would need the module to tell.
Mark
Mark
