I understand there is a 1" adjustment for tour paks. How do I determine if mine is in the forward position or rearward. I'm wanting to move it back to the rearward.
Very simple look under the Tour Pak and you will see the other set of holes. Remove the bolts that mount the Pak to the rails and move it back to the other holes reinstall the bolts. You'll have to remove the liner in the Tour Pak to get at the bolts. \
