XiED ViED 105
XiED ViED 105
I pulled the trigger on http://sales.nightrider.com/ViED_p_13.html
For those who have installed these, where the heck can I get a clean Ground ?
Got some pics , what about keeping them from frying from the heat ???
I was thinking running the 13.8:1 for my No--Cat , Slip on Reinharts, Stage 1 download + SE A/C ....
I liked the "Adjusatbility" but love to get some feed back Pictures would be great..
Thanks in advanced
ViEDPart Number 105
Adjustable AFR device for your bike requiring nothing more than a small screwdriver.
Riders can quickly and simply richen the closed loop fuel mixture on your Twin Cam,
Recommended for HD bikes with OEM emissions downloads. These include
Thanks in advanced
ViEDPart Number 105
- TC96, Stage 1 -- I have this Set Up, stuck with a Calif. 50 state down load
Trackadapter's is spread out more as his 02 sensors are in different place on the header pipe. When I had my 08 uc and bought the XIED'S, I ty-raped the front sensor wire down in front of the front downtube frame. Theres plenty of wire. All you have to do is keep it away from the exhaust. . Pretty simple. Steve might have a video of the install. If he doesn't, I'm sure he will be glad to talk you through it. He's a nice guy to deal with.
Your's is like my 2010. It's a very simple install. Pull your right side cover. Your 02 sensor cables are side by side color coded. I'm sure you can find a good ground without going to the battery, but it's so close, I ran it to the negative battery post.
Just got them via. Snail mail
Thanks for the advice , I will try and take pics and post my fidings
I hope there is enough wire to hook to battery ground..... will see
DaneKirk
08-20-2010 10:48 AM
