Intermittent Oil Light
The other day I was out and caught in the rain. I noticed the oil light was flickering intermittently but not staying on. I came home and the next day changed oil and filter (needed it anyways) and swaped out my oil pressure switch with my brothers. THe light didn't come on again right away but after warming up it started again. The longer I rode the stronger it seemed to try and come on when finally it would stay. Oil pressure gauge is fine and bike sounds normal.
What I did notice was if I accerlerated the light disappeared, as it rev'd down or I kept it at a constant the light would come back on. I stopped riding and got it home but I'm lost now.
Changed oil and filter
swaped out oil pressure switch with brothers and it didn't show any issues on his.
Light goes when rev'd.
Help??? Ideas???
Help??? Ideas???
Sounds like an electrical fault. You may have a poor ground for the warning light, or two wires touching, something like that. May also be worth checking your charging, just in case that is below par. This is the sort of thing you will either find easily, or take ages to hunt down! Best of luck.
1 Post
I had the exact same problem with my 05 Ultra. Replaced the oil pressure switch, but still had the problem. I pulled the cam plate and oil pump. When I checked the cam tensioners, they were chewed up pretty bad. I took apart the oil pump, and noticed that the walls of the pump had fine scratches and was causing a loss of pressure.
I went with the SE camplate and highflow oil pump ($429.00) and the problem was solved.
1 Post
Oil pressure switch activates both the oil light and pressure guage on touring models. If the light comes on and the psi on the guage is below 30 while running, then it could be the switch. But you say you swapped out the switch and still have the same problem, so it's not the switch. The only terminals that are exposed to rain are at the switch, and after a few days would have dried out.
The easiest way to find the problem is to remove the pressure switch and replace it with a pressure guage. I went to a hardware store and picked up a gauge, fittings and a stainless steel supply line and made my own.
bike, electra, flickering, glide, harley, intermitant, intermittent, light, oil, pressure, revd, sportster, starts, trike, vw
