PC Racing Re-Useable Oil Filters ?
I guess I better change back to the Harley 360 oil that came in my bike from the factory. My Spectro Platinum Synthetic 20-50 will void my warranty. Better get rid of my Spectro 6 speed oil, it's no good either. I won't even mention that I use Spectro Heavy duty primary oil.
I could post this in the oil section but touring gets ton more looks. Anyone here using the PC Racing re-useable oil filter? It looks similar to the K&P type. I can get one thru my bro-in-law for about $80 and thinking about giving it a try. Input appreciated, Thanks
http://pcracingusa.com/store/product_info.php?products_id=169
Aw hell, I decided to give it a try. I'm not concerned about the micron ratings as industry standards are very vague. What intrigues me the most is the higher flow ability of the filter. I'll get it installed next week and will report back about the ease (or not) of cleaning it at oil changes...
Yes, I use it, and it is a superior product in every way. It filters more thoroughly, flows oil more easily, pulls out particles with a magnet, has an integral hex head for a socket (as does the K & N), and cools the oil somewhat by its finned design. And yes, it looks real cool also. True, it was close to $100
bucks, but my Amzoil is not cheap either. I believe that my catless head pipes and the oil cooler has done much to soothe my Twin Cam.
First of all, it does not flow better because it filters less. This is a common misconception that I once also held, so in no way am I pointing a finger.
Second, 35 microns can in fact be a better filter than 8 microns due to the consistency of filtration. Don't be offended, I am not a gear head and did not understand this either. However, to some degree I do now.
Please check it out, not only from this manufacturer, but others as well.
smokingjoe
Milwaukee Eight (M8)
37
07-24-2017 10:44 AM
