Mounted GPS to the inner fairing
I've had my GPS mounted to my handlebars with a RAM mount and plugged into the lighter socket. The clutter really bothered me; so I decided to mount it on the fairing.
To do it I purchased a threaded RAM ball, short 1.75" arm, and a power cable to hard wire it from www.mountguys.com. There are accessory plugs off the headlight wire so all I had to do was add a couple of spade terminals to the lead wires from the GPS cable. I already had the RAM cradle. I drilled a 1/4 hole in the upper part of the fairing and ran the hard wired cable through the clutch cable hole. Nice and clean. The only issue I have is it vibrates a little at speed, not bad but I wish it was better. I never considered that it would do that since its always been perfect on the handle bar and at idle its perfect. You'd figure if it's okay at idle then moving wouldn't be an issue. Anyway; to quote Billy Crystal as "Fernando": It's always better to look good than feel good, I always say"
And it does look good. Very clean looking.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
General Inquiries:
Phone:
775.331.3789
I did the same thing. I have a Garmin Nuvi 765t instead of using my IPhone now.
Attachment 190494Attachment 190495
At one time I was considering locating mine on the dash but was concerned that it might possibly crack the dash due to the rough Ideal and the vibrations...Although there has been several cases where members have located in on the inner fairing and hasn't had any ill effects as of yet...
So I got to thinking...
I didn't like the way it mounted to my handle bars and left the ring from the U bolt endented in it and didn't feel the factory mount that was supplied with my Zumo was the look bolted to the perches clamps I was seeking when the GPS was off, so I pursued other options and came up with this...
I have 1 1/4 dia. PYO monkey Bars by the way
https://www.hdforums.com/forum/touri...gps-mount.html
I don't run my GPS all the time and wanted a cleaner look when it was off the bike as well as when it was on the bike and came up with something I personally thought fit what I was after and didn't have to drill into the dash...
